afight
May 18, 2025Star
Orbi continually disconnects
I had the RBR50 with one satellite for many years and it worked perfectly. Then one day, it started dropping connections and slow connections. I thought it was due to be replaced since we had it for ...
afight
Feb 28, 2026Star
Good luck to all that lad on this topic trying to resolve this issue. I asked chatGPT about the top issues with this system ….seems like my issue is a prevalent one. Sad part is that you think a system this expensive will be magical. Instead you get stuck in a months long troubleshooting cycle that is incredibly frustrating and puts you beyond a return window. If you are still in your return window - RETURN IT NOW! Learn from my mistake.
From chat:
Here’s a structured **summary of reported top issues with the NETGEAR Orbi RBE971 (Wi-Fi 7 flagship mesh router) from user posts/forums and whether people found any resolutions:
1. Frequent Wireless Dropouts & Reboots
Reported:
- Users frequently describe Wi-Fi dropping entirely (SSID stops broadcasting) then needing reboots to restore connectivity.
- Some report random daily signal loss and satellites disconnecting unexpectedly.
- Firmware instability has been implicated (especially earlier builds).
Troubleshooting & Resolutions:
-Some users find that manually rebooting the router and satellites restores service temporarily.
-A few threads note that new firmware under QA was rolled out to address pixel device instability.
-No widespread confirmed fix — many were waiting on official firmware updates.
2. Firmware Behavior & Satellite Reconnect Issues
Reported:
- After updating to certain firmware (e.g., 9.12.2.1), users noticed weird behaviors — new unexpected SSIDs and satellites failing to reconnect without factory resets.
-Some users had to factory reset satellites after router reboots for them to rejoin.
-Netgear support acknowledged the issue and suggested firmware fixes.
…etc
Feb 28, 2026Guru - Experienced User
Do you still have the 970 series system?
