afight
Apr 22, 2025Star
ORBI dropping connection - replaced same issue - with VPN works
After 5+ years of no issues, I started having devices dropping and not able to load on my Orbi RBR50. I made the $1300 upgrade to the RBE971 and am having the same, if not more problems. Here are s...
- Apr 22, 2025
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Try using custom DNS services on the RBR. Try Cloudfare or Quad9
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
Apr 22, 2025Guru - Experienced User
Couple of options,
