afight
Apr 22, 2025Star
ORBI dropping connection - replaced same issue - with VPN works
After 5+ years of no issues, I started having devices dropping and not able to load on my Orbi RBR50. I made the $1300 upgrade to the RBE971 and am having the same, if not more problems. Here are s...
- Apr 22, 2025
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Try using custom DNS services on the RBR. Try Cloudfare or Quad9
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
afight
May 18, 2025Star
IPv6 was the problem. This fixed the issue that same day. Thanks for a great response!
