procreator
Jul 24, 2026Tutor
Orbi RBE360 and Epson ET-3958
After spending way too much time with Epson tech support, I was told that even though their printer was compatible with 5gHz or 2.4gHz, it does not play nice with mesh router systems. Their suggestio...
Jul 24, 2026Guru - Experienced User
procreator wrote:Their suggestion was to use a LAN cable to connect the printer directly to the main unit of the Orbi.
If you can connect to a satellite instead, then try that.
FWIW, we have two epson printers (different models) that work well when connected to our Orbi wifi.
