procreator
Jul 24, 2026Tutor
Orbi RBE360 and Epson ET-3958
After spending way too much time with Epson tech support, I was told that even though their printer was compatible with 5gHz or 2.4gHz, it does not play nice with mesh router systems. Their suggestio...
Jul 28, 2026Guru - Experienced User
Thats got an older wifi 5 chip in it. Some had issues with AX much less BE. I can't remember if that version of orbi has an IoT option. If it does, set that up with wpa2 only mode. see what happens. You should have wpa2/wpa3 mixed mode running for wifi security.
- StephenBJul 29, 2026Guru - Experienced User
It does. See page 60:
- https://www.downloads.netgear.com/files/GDC/RBE362/RBE361_RBE360_UM.pdf
- schumakuJul 29, 2026Guru - Experienced User
Same radios for the IoT network, just individual settings for SSID, band, shared key. In case the issue is really an interop issue with AX or BE, you will see...
