procreator
Jul 24, 2026Tutor
Orbi RBE360 and Epson ET-3958
After spending way too much time with Epson tech support, I was told that even though their printer was compatible with 5gHz or 2.4gHz, it does not play nice with mesh router systems. Their suggestio...
- Jul 30, 2026
Thanks for all the ideas.
I bought a cheap TP-Link WiFi Extender with an Ethernet port. The extender plugged into a wall outlet 4ft from the printer.
Works great!
procreator
Jul 30, 2026Tutor
Works great!
Jul 30, 2026Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
