willb_1968
Dec 03, 2025Aspirant
orbi RBE371 seems to be munging IP traffic from wifi to ethernet?
Just upgraded my home wifi to Orbi RBE371 with one satellite. Previously I had an asus zenwifi mesh system. Firmware is V12.1.3.11_5.1.12 Everything is working pretty much as expected, very happy ...
willb_1968
No, 10.0.0.111 is the address of the Orbi on the WAN side.
Dec 03, 2025Guru - Experienced User
willb_1968 wrote:No, 10.0.0.111 is the address of the Orbi on the WAN side.
You must be double-routing, since 10.0.0.111 is a private (not internet-routable) address.
It sounds like you must have the ethernet connection going to the other router, and not the Orbi.
If you are only using the Orbi for wifi, then you should consider setting it up in AP mode.
- willb_1968Dec 03, 2025Aspirant
yes, I'm currently double routing (the modem is an xfinity gateway in router mode).
I realize this isn't a common configuration, I'm not necessarily opposed to putting the gateway into bridge mode and leaving the orbi in router mode, but I am currently using multiple ethernet ports on the gateway (one for the orbi, a couple for other devices I don't really need on the orbi network), so I'd have to move those devices behind the Orbi if I do go in that direction (this will be a small one-time annoyance).
The thing is, I don't understand why double routing would produce this observation. The raspbery pi shouldn't think my ssh connection is coming from the 10.0.0.111 address, I expect to see 192.168.0.50, which is the address my laptop has. This weekend I can experiment a bit with putting the gateway into bridge mode, and I also can try leaving the gateway in router mode and putting the Orbi into AP mode (this would be my least favored permanent configuration option, though).
I'll try it out and report back.- StephenBDec 03, 2025Guru - Experienced User
Is the pi connected to the gateway network (either via ethernet or wifi)?
- willb_1968Dec 04, 2025Aspirant
No, it's only connected to the orbi, the wifi is on the regular (non-guest/non-iot) orbi wifi network and the ethernet is connected to a switch that is connected to the orbi.
there's another pi that is only connected via ethernet (through the same switch), and a 3rd pi that is only connected via wifi (to the same regular wifi network on the orbi only). None of them are connected to the gateway.
here's a view where from the same laptop I have ssh'd to both the ethernet and the wifi:
$ w 06:51:49 up 6:52, 2 users, load average: 0.05, 0.07, 0.08 USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT user 192.168.0.50 06:51 6:52m 0.00s 0.10s sshd: user [priv user 10.0.0.111 06:21 6:52m 0.00s 0.10s sshd: user [privhere's the ifconfig from that pi:
$ ifconfig -a br-aa29e18e95ac: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 172.30.9.1 netmask 255.255.255.0 broadcast 172.30.9.255 inet6 fe80::b808:dff:fe5d:2685 prefixlen 64 scopeid 0x20<link> ether ba:08:0d:5d:26:85 txqueuelen 0 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255 ether aa:05:26:77:7a:c9 txqueuelen 0 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.4 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fda8:d24d:b2be::1c2 prefixlen 128 scopeid 0x0<global> inet6 fda8:d24d:b2be:0:dea6:32ff:fed9:14dc prefixlen 64 scopeid 0x0<global> inet6 fe80::dea6:32ff:fed9:14dc prefixlen 64 scopeid 0x20<link> ether dc:a6:32:d9:14:dc txqueuelen 1000 (Ethernet) RX packets 133658 bytes 20604270 (20.6 MB) RX errors 0 dropped 1 overruns 0 frame 0 TX packets 461496 bytes 32713016 (32.7 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 24 bytes 3602 (3.6 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 24 bytes 3602 (3.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 veth8ca7352: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet6 fe80::3c3b:52ff:fee8:84f prefixlen 64 scopeid 0x20<link> ether 3e:3b:52:e8:08:4f txqueuelen 0 (Ethernet) RX packets 32177 bytes 4418121 (4.4 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 28574 bytes 3763866 (3.7 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 vethe6bbbff: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet6 fe80::5c6e:1ff:fe8f:1645 prefixlen 64 scopeid 0x20<link> ether 5e:6e:01:8f:16:45 txqueuelen 0 (Ethernet) RX packets 18660 bytes 2548135 (2.5 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 19035 bytes 3581595 (3.5 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.156 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fda8:d24d:b2be:0:dea6:32ff:fed9:14dd prefixlen 64 scopeid 0x0<global> inet6 fe80::dea6:32ff:fed9:14dd prefixlen 64 scopeid 0x20<link> inet6 fda8:d24d:b2be::2db prefixlen 128 scopeid 0x0<global> ether dc:a6:32:d9:14:dd txqueuelen 1000 (Ethernet) RX packets 1162 bytes 77016 (77.0 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 327 bytes 28761 (28.7 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
