Altaer
May 30, 2025Guide
Orbi RBE771 Latency issues every 60 minutes
Ever since purchasing RBE771 back in October of 2024, I have dealt with an issue where every 60 minutes exactly on the dot my internet has super high latency for 30-60 seconds, and then returns back ...
Altaer
Nov 21, 2025Guide
November 21, 2025 update: I factory reset my Orbi and satellite and the issue still persists and is as prevalent as ever.
Nov 21, 2025Guru - Experienced User
What FW version is currently loaded on the system?
- AltaerNov 21, 2025Guide
Right now v10.5.19.5, though the problem has existed for every update since the beginning of the 771 series
- FURRYe38Nov 21, 2025Guru - Experienced User
Can you please load up this newest FW version, RBS first then RBR lastly:
New - RBE770 / RBE771 Firmware Version 10.5.20.7 Released | NETGEAR Communities
Try a power OFF of the RBS and RBR AFTER the system has been fully updated, for 1 minute then back ON.
- AltaerNov 25, 2025Guide
I updated to the 10.5.20.7 firmware using your instructions and it unfortunately did not resolve the issue, which isn't a surprise considering the patch notes were to resolve a security issue
