irishleeriley
Apr 20, 2026Aspirant
Orbi RBE871 not recognizing all devices on Wifi
Our network worked fine until a few weeks ago. (We have a router and one RBE870 satellite.) Now it's not showing all devices as being connected, even when they are connected. I can look in the app an...
- Apr 21, 2026
So how many devices in total do you have connected at once? Wifi and Ethernet.
Other than the UI or Orbi app not seeing all devices, does the system seem to be working ok?
Can you perform a full on factory reset and setup from scratch please. Please follow this guide:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
There has been some known issues with this version of FW. Will pass this to NG for review.
irishleeriley
App version 2.52.0.42 - it's the same on iphone and ipad.
Website only shows devices that are connected, offline only shows MAC address, so I can't identify.
Home approx 5300 sq ft
More than 30 feet to satellite
Modem - Nighthawk Model CM2050V
Using Xfinity internet, don't know about IPv6
Only have 2 wired, they're fine. Seems to only affect wireless.
Wireless 2.4 and 5 enabled; WPA2-PSK + WPA3-Personal enabled
Armor not activated; parental control not activated; traffic meter not activated
Haven't tried a factory reset or setup from scratch.
Apr 20, 2026Guru - Experienced User
What channels are you using for 2.4 and 5Ghz?
Be sure to disable any MAC Address randomizers on phones and pads while at home...
