Blairgowrie's avatar
Blairgowrie
Orbi router / satellite continual drop out
I have a new 770 series after installing I had a period of good service but now the satellites disconnect daily
I have to power reset all and resync
netgesr support log it but then tell me to call which I’ve tried but can’t get an answer
all units are no same firmware release
it’s a total pain
  • FURRYe38's avatar
    Are RBS ethernet or wirelessly connected to the RBR?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channel configurations are currently set on the router?
    Setting up with Orbi app or PC and web browser?
  • FURRYe38's avatar
    Any feedback to the questions presented?
    it’s a total pain
  • FURRYe38's avatar
    Any progress on this?
    it’s a total pain
