kevinhai
Jul 11, 2025Aspirant
Orbi Router (RBE771) Persistent Amber Power Indicator Light
Hi All, Issue: Need assistance with a possible failed update on my Orbi Router (RBE771). I have tried holding the reset button and nothing happens. Symptoms: No front status light glow and the back...
Jul 11, 2025Guru - Experienced User
Try a 30-30-30 Reset.
Can see if NMRPFlash will help as well:
https://github.com/jclehner/nmrpflash
