Dec 14, 2023Guru - Experienced User
Orbi Satellite Information and FAQ
Good article, information and resources on Orbi system satellites:
https://www.netgear.com/hub/wifi/mesh/orbi-satellites/
- Nov 04, 2024
Here is a good tested method to access and RBS should they not correctly sync due to there firmware being mis-matched or out of date and need a manual firmware update to get them in sync with the RBRs firmware number and synced back with the RBR.
Please download the process PDF file and review the steps.
Good Luck.
Nov 04, 2024Guru - Experienced User
Good Luck.
