BANsOnLn
Dec 26, 2025Guide
Orbi VPN can't remote control MAC mini
I have set up the VPN server on my Orbi RBE771. I can get connected to the VPN from my MacBook Pro and access my Sonarr and Radarr web interfaces. I can even pull up network and see the devices on th...
KevinLiT
Dec 26, 2025NETGEAR Moderator
Hello BANsOnLn,
Welcome to the NETGEAR Community!
I understand that you are not able to connect to your devices through the VPN that installed on your RBE771. The ability to connect to your internal network successfully establishes that you RBE771 is working correctly. The ability to see your attached devices establishes that the VPN is also functional. Due to security measures additional configuration may be needed on the devices side to establish the remote access.
Best,
Kevin
NETGEAR Team
