adonf06
Nov 28, 2025Aspirant
Password not recognized on satellite RBE970
I can't connect to the satellite, even after a factory reset and resynchronization. Neither "password" nor the original password on the label works. Any ideas?
- Dec 01, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
adonf06
Nov 30, 2025Aspirant
Sorry for the delay, I was traveling.
Thank you for your feedback. Unfortunately, I've tried everything :(
For various reasons, I can't connect the Orbi devices directly to the internet. So I'm using my local Linux PC.
I started from scratch, with the RBR and the two RBS devices on my desktop:
- Factory reset of the RBR
- Wi-Fi connection from my Linux PC to the RBR at 192.168.1.1 (obtaining an IP address of 192.168.1.38 for my PC)
- Factory reset of the two RBS devices, then waited a few minutes : the two RBS devices were automatically reattached to the RBR (at 192.168.1.38 and 192.168.1.82.
I then want to manually update the RBS devices using files downloaded from the Netgear website.
On the manual update page, when I check the box corresponding to the first RBB and click "UPDATE," a popup appears with the URL 192.168.1.138 of the first RBS, asking for my login/password.
Can you confirm that it is indeed the "admin" / "password" combination?
An important point: due to a bug in the firmware I'm currently using (9.12.2.1), I had to bypass the step involving the two security questions at the beginning of the RBB setup by opening a new tab and "patching" the step number.
I contacted Netgear support at the time, and they confirmed the existence of this bug and that there was no other way around it.
Therefore, I never had to provide a password ! That's why I'm asking about a default password...
adonf06
Dec 01, 2025Aspirant
I finally solved my problem.
Not knowing the RBR password, I went through the password reset procedure by answering the two questions.
The satellites then resynchronized with the router, which provided them with the new password.
I was then able to connect to the satellites and complete the update process.
- FURRYe38Dec 01, 2025Guru - Experienced User
Enjoy. 📡
