Woggles
Jan 03, 2026Follower
Port forwarding with Comcast
I am putting my Comcast XB7 modem/router in to bridge mode and connecting to an Orbi 370
I am doing this to avoid the Comcast router not doing port forwarding even though I set that up in the Xfinity app
The XB7 has several Ethernet ports. I have one that goes to a Verizon micro-cell and another that goes to some old vintage commercial computers. So I want to put a simple Net Gear switch at the main Orbi's Ethernet port. Is that going to be a problem? I need the three Orbis to be upstairs, so I have a long cat 5 to the vintage equipment in the basement.
So 1) Is there any issue anyone is aware of to put in a port forward to ports 22 and 23 with a switch in-line?
2) Can I have one vintage computer be port forwarded to via two different ports?
3) Is anyone aware of Comcast "features" such as their "advanced security" getting in the way of this?
When using Port Forwarding, be sure to disable uPnP. Also disable any security features like Armor as well.
Typically when the Internet Service Provider device (Comcast XB7) is put into bridge mode, it expects to connect to one device with one hardware MAC address.
This configuration does not appear to be compatible with bridge mode.
Port forwarding is a "one to one" situation. Packets addressed to one specific port on the Public IP address are forwarded to one specific port on one specific IP address on the LAN.
Thus, it is certainly possible to forward ports 22 and 23 through the router to the same computer
The articles that come up on the internet about forwarding ports through the XB7 mention disabling Advanced Security. Perhaps that is why it is not working?
