rclong
Jul 10, 2025Guide
Ports report 'closed' instead of 'stealth'
I just installed the RBE771/770 and ran Gibson Research's (grc.com) Shield's Up! 'port authority' scan. It reports that all ports are "closed", which means they are detectable by scans from the Inte...
rclong
Jul 18, 2025Guide
I'm working with Netgear support on this issue and will report back if/when there is a solution.
