maxbloise
Oct 13, 2025Follower
Power Adapter Voltage Range
Hello everyone! I'm planning to buy this set: https://www.netgear.com/home/wifi/mesh/rbe973sb/ Is there any RBE973 owner / Netgear member that can confirm that the power adapter volatage rang...
CrimpOn
Oct 13, 2025Guru - Experienced User
It would have been helpful if the Original Poster (OP) described the reason for asking the question. I have a suspicion that perhaps the intent is to purchase the system in the U.S. but then at some future date relocate it to a part of the world that has 240v power rather than the 110v in the U.S. If the power supply supports all voltages, then only a simple "plug adapter" would be required.
If not, then new power adapters would be required. Netgear provides part of the information required to purchase replacement power supplies:
Netgear does not specify the dimensions of the power plug that goes into the router/satellite. Nor do many of the products for sale on Amazon that claim compatibility. (One product helpfully shows this picture)
