jefferis
Mar 23, 2026Guide
Printer's IP seen, but cannot connect
On a Mac with Tahoe 26.x.x Logging in to the Orbi dashboard, my two printers are clearly seen with valid IP addresses. But when I try to connect and print, they say offline. One is wifi to the RB...
Mar 23, 2026Guru - Experienced User
What model Orbi system do you have?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Is the printer connected to the RBR or the RBS?
Setup a ip address reservation for the printer on the RBR? or set a static IP address ON the printer itself that the address resides outside of the RBRs default IP address range.
Be sure to disable any MAC Address randomizers on phones and pads and Mac PCs while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
