LWOH
Sep 13, 2025Follower
Purchased RBE771 and RBE770 as a set in October 2024
Purchased RBE771 and RBE770 as a set in October 2024. Satellite started disconnecting from router in August 2025. These are the first issues I've had with a Netgear satellite repeatedly disconnecti...
CrimpOn
Sep 15, 2025Guru - Experienced User
When a configuration has worked without problems for 10 months and then begins failing repeatedly, it can be useful to ask, "what changed?"
Firmware version 10.5.19.5 was released on July 8, 2025. Could you please check to see what version of firmware is running on this system?
https://kb.netgear.com/000067270/
The previous version, v110.5.18.3, was released March 26, 2025.
https://kb.netgear.com/000066615
It is a bit frustrating that Netgear does not provide a method to determine when firmware was updated on a specific system.
