LWOH
Sep 13, 2025Tutor
Purchased RBE771 and RBE770 as a set in October 2024
Purchased RBE771 and RBE770 as a set in October 2024. Satellite started disconnecting from router in August 2025. These are the first issues I've had with a Netgear satellite repeatedly disconnecti...
Sep 15, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
10 feet is too close to between the RBS and RBR. 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. And regardless of prior experieces.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
Please move the RBS out to 30 feet from the RBR.
LWOH
Sep 21, 2025Tutor
Thank you for your thoughtful reply. The firmware is up to date for the router and satellite and the modem and router are working fine. There isn't a reference to minimum distance between the router and satellite in the Netgear documentation for this product or in the information contained in the link you provided. The Netgear troubleshooting procedure says to move the satellite to the same room as the router, so I don't think the distance between the router and satellite are the issue.
- FURRYe38Sep 21, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What is the size of your home? Sq Ft?
10 feet is too close to between the RBS and RBR. 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. And regardless of prior experiences. There used to be a KB article about distances but NG took it down from unknown reasons. So these are valid and current recommended starting distances between the RBR and RBS.
