menozzi2
Sep 12, 2025Aspirant
RBE 371 wifi speeds
I was using a Orbi RBR40, I set up my new RBE371 with two sats and set up was easy. I have Spectrum gig internet. I got a slight bump (300mps to 430mps) in download speed, upload is about 40 now as o...
Sep 12, 2025Guru - Experienced User
What is the ethernet test speeds on the Mac Book Pro? You should see near or just over 900Mpbs over the wire.
Is the MBP connected near or at the RBR when speed testing? Turn OFF the RBS to check this.
Make sure the MBP is connecting at 5Ghz. However at most, You may see or should see around 300-700Mpbs depending on conditions and such. I have seen near 700Mbps or just over with same MBP I have on a AX system in history. The MBP is only AC supporing so anywhere around 500-600Mpbs max realistic speeds will be about the limit.
What OSX version is on the MBP?
What channels are you using? I use 1 and 40 here most of the time.
menozzi2
Sep 14, 2025Aspirant
Thanks for the response. Ethernet speed is terrible. May be caused by a switch I'm using, I'll upgrade that tomorrow and recheck.
MacBook is about 7 feet from the RBE371.
MBP is running 15.6.1
WiFi is a mixed 2.4 and 5mhz to allow for some devices that are not 5mhz.
WiFi is running at 300mbps, so it sounds like I can reasonably expect more speed over wifi.
Channels are currently set to auto, 2.4ghz is channel 4, 5ghz is channel 36.
speed test on the router using the orbital app is 1155Mbps download.
I can switch the channels but is there a way I can tell which channels have the least traffic?
