menozzi2
Sep 12, 2025Aspirant
RBE 371 wifi speeds
I was using a Orbi RBR40, I set up my new RBE371 with two sats and set up was easy. I have Spectrum gig internet. I got a slight bump (300mps to 430mps) in download speed, upload is about 40 now as o...
CrimpOn
Sep 14, 2025Guru - Experienced User
MacBook Pro 2018 specs can be found here:
https://support.apple.com/en-us/111949
5GHz WiFi 802.11ac (WiFi5) is capable of 400+ Mbps speed. WiFi speed varies dramatically with distance between WiFi access point and mobile device. When you eventually upgrade to a newer MacBook, the speed will increase dramatically.
