Chuck_M
Apr 24, 2026Mentor
RBE 971 Auto Firmware Updates - I have questions!
Haven't been on here lately but on a whim thought I would check to see if Netgear has updated any firmware. I left shaking my head wondering what the heck is going on these days with Netgear. I...
Apr 24, 2026Guru - Experienced User
v12 was accidently posted when it shouldn't have been.
NG is working on new FW and will release it when it's ready. It's in testing currently.
AU services are just disabled for now as to help ensure nothings gets pushed accidently.
v12 will be a major update when it arrives.
All FW updates can be seen here for the 970 series:
https://www.netgear.com/support/product/rbe972s
Please be patient. Thank you.
Chuck_M
Apr 24, 2026Mentor
Thanks Furry!
Any idea why the huge jump in next version number? If that means anything, it sounds like a major revamping.
- FURRYe38Apr 24, 2026Guru - Experienced User
New Wifi stuff.
- Chuck_MApr 28, 2026Mentor
Normally that would be a version increase of 1. 9.6 to 10.0 or something like that.
- FURRYe38Apr 28, 2026Guru - Experienced User
Maybe, however doesn't have to be. Maybe based on tested versions or core code that was built at that version. Also NG may not set the version either, may come from ODM or Chipset Mfr as well.
