golf18
Oct 27, 2025Tutor
RBE770 and Sky Hub
Hi, I have just upgraded my RB50 due to end of life to a new RBE770 and RBE771. All set up but last night my sky Q box could not log on to the sky Hub. I am wondering if the new setup is blocking th...
- Oct 27, 2025
Something to contact SkyQ ISP about regarding there equipment.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communitieshttps://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Oct 27, 2025Guru - Experienced User
Couple of options,
