golf18
Oct 27, 2025Tutor
RBE770 and Sky Hub
Hi, I have just upgraded my RB50 due to end of life to a new RBE770 and RBE771. All set up but last night my sky Q box could not log on to the sky Hub. I am wondering if the new setup is blocking th...
- Oct 27, 2025
Something to contact SkyQ ISP about regarding there equipment.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communitieshttps://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
KevinLiT
Oct 27, 2025NETGEAR Moderator
Hello golf18 ,
Welcome to the NETGEAR Community!
I understand that you would like more information about configuring the RBE771 to work with your existing network infrastructure.
FURRYe38 Was correct in this matter.
Since there has been no network configuration changes, the issue was most likely caused by your internet service provider.
The question about using the Orbi Mesh system in AP mode depends on your networking needs. If you are using your Orbi system to simply extend your wireless network, then you would benefit from placing your Orbi Mesh system in AP mode.
However, if you a complex network setup that includes devices such as privately hosted DNS servers, then it will be beneficial to enable bridge or pass-through as mentioned by FURRYe38 on your ISP router.
Best,
Kevin
NETGEAR Team
