Dahbawz
Sep 13, 2026Aspirant
RBE770 v1 satellite stops accepting WiFi clients – reboot immediately fixes it – V10.5.20.10_2.2.51
Hi all, I am experiencing a recurring issue with my Orbi 770 system and, after quite a bit of troubleshooting, this does not appear to be a normal roaming, coverage or client-side issue. Before ...
Rinkster
Oct 02, 2026Aspirant
Same issues here as well on the same HW/FW. I've been running Network Live Monitor on my home network and when the Satellites lose connection, it's either for less than 1 minute or 4 minutes. Typically, the satellites will come back on their own, but there are times when I must physically reboot them even though status shows "good".
I've also had both satellites in the same as the router with the same results.
Funny enough, when I was typing this message, my downstairs satellite went off-line for 4 minutes.
Timestamp,Event,Device Name,IP Address,Status,Ping,Uptime %
2026-10-02 14:53:08,ALERT,Downstairs Satellite,192.168.77.43,DOWN,---,68.9%
2026-10-02 14:57:31,RECOVERY,Downstairs Satellite,192.168.77.43,UP,13ms,68.7%
I sure hope NG publicly releases the update soon if we cannot gain access to the beta version.
