elizabethmalec
Aug 26, 2026Follower
RBE770/RBE771 consistent internet drops when connecting to VPN
hello, when using my laptop to vpn remotely the connection when it is 1st being established will consistently connect, drop, reconnect at a minimum of 3 times before it becomes "stable." this AL...
schumaku
Aug 27, 2026Guru - Experienced User
HappyCat wrote:This discussion appears to be about using the Cisco Secure Client AnyConnect VPN on a laptop connected to the Orbi 770 system.
Yep, However, I can't find any proof if that happens on establishing a TAP or a TUN VPN session.
The OP should evaluate the powerful Windows event log FMI on what is exactly happening while the OpenVPN session is starting.
There is a very similar thread on the Cisco Community - completely independent of Netgear and OpenVPN - where users show repeated reconnects from VPN clients. Especially those with multiple network adapters (WiFi, LAN, VPN, ...).
Pretty much convinced, there is nothing wrong with these reconnects - multiple interfaces/adapters, routing changes, ...
Aug 28, 2026Guru - Experienced User
schumaku wrote:Yep, However, I can't find any proof if that happens on establishing a TAP or a TUN VPN session.
I just double-checked, and my memory here wasn't quite right. The default VPN profile for Windows actually is set up for TAP, while the smartphone profile is set up for TUN.
TAP is what didn't work for me on my Orbi 870. I never got a useful VPN session. Switching to TUN resolved that problem. Since elizabethmalec is already using TUN, then there is no need for her to test with TAP.
schumaku wrote:Pretty much convinced, there is nothing wrong with these reconnects - multiple interfaces/adapters, routing changes, ...
Which is why I suggested that if she is ending up with a stable connection, she might just leave well enough alone.
