gemuens
Jul 24, 2026Aspirant
RBE771: 6th wired satellite missing / 5th Config Sync
Hello, I am seeing what appears to be a reproducible issue with my Orbi RBE771 running firmware V10.5.20.10. Hardware Router: RBE771 Satellites: 6 × RBE770 Firmware: V10.5.20.10 on router and...
Jul 24, 2026Guru - Experienced User
What happens if you have one of the RBS wireless instead of wired, leaving 5 RBS ethernet connected?
What is the model# switch that all the RBS are being connected too?
All RBS have same FW version as RBR?
Size of home in sq feet?
Not many home users have 6 RBS connected. I only use two which is plenty for my 5K sq ft home. Ethernet connected.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
