gemuens
Jul 24, 2026Aspirant
RBE771: 6th wired satellite missing / 5th Config Sync
Hello, I am seeing what appears to be a reproducible issue with my Orbi RBE771 running firmware V10.5.20.10. Hardware Router: RBE771 Satellites: 6 × RBE770 Firmware: V10.5.20.10 on router and...
Jul 26, 2026Guru - Experienced User
What happens if you have one of the RBS wireless instead of wired, leaving 5 RBS ethernet connected?
That size of home, not sure if having a 6th would be of benefit.
gemuens
Jul 28, 2026Aspirant
The result was the same. Attached Devices shows only five satellites, all as Wired/Good. The 6th satellite still does not appear on the Attached Devices page, although it continues to appear on the Firmware Update page.
- gemuensJul 29, 2026Aspirant
Correction: The Attached Devices page showed only 5 satellites, 4 Wired/Good, 1 Wired/Config/Sys. The 6th satellite does not appear on the Attached Devices page, although it continues to appear on the Firmware Update page.
- FURRYe38Jul 29, 2026Guru - Experienced User
Will check and see if this is a limitation or an issue with FW. There was some discussion on how many RBS could be connected at once. Not sure what became of that.
You might contact NG support and see if they know of this as well...
- gemuensJul 30, 2026Aspirant
Thank you. If this turns out to be a FW issue rather than a documented limitation, would you be able to escalate it to the Netgear engineering team? My testing shows the sixth satellite is fully operational and appears on the FW Update page, but never on the Attached Devices page.
