gemuens
Jul 24, 2026Aspirant
RBE771: 6th wired satellite missing / 5th Config Sync
Hello, I am seeing what appears to be a reproducible issue with my Orbi RBE771 running firmware V10.5.20.10. Hardware Router: RBE771 Satellites: 6 × RBE770 Firmware: V10.5.20.10 on router and...
gemuens
Jul 31, 2026Aspirant
Hi,
As requested, I collected the debug logs from both the RBR771 and the RBS770 satellite (192.168.1.140).
The logs were collected with firmware V10.5.20.10 while all six satellites were connected.
https://1drv.ms/f/c/2f10a57e9c29b4d0/IgBrOZaeUsNsRK9_1RG3KFrAAUlK40jQznuWd7b5zdeqs-o?e=05lmsH
https://1drv.ms/f/c/2f10a57e9c29b4d0/IgBUXNW4gYGQTJDkZOTOCKdxAd7R-qZBbYSDFZg71JFR0D4?e=zyFAXF
Earlier, this satellite did not appear in the Attached Devices page, although it did appear in the Firmware Update page. Before collecting the logs, the Attached Devices page refreshed and the satellite became visible (now showing all 6 satellites, wired/good).
Thank you for forwarding these logs to Netgear engineering.
Aug 01, 2026Guru - Experienced User
Thank you for collecting. Passed on to NG.
