ocnblue
Oct 15, 2025Tutor
RBE771 Connection Constantly Dropping
I have an RBE771/RBE770 that I have had running for just under a year. My current setup I am using Ting and I get 2GB up/down. They have a fiber modem which I run into the Orbi and I also have a NET...
CrimpOn
Oct 15, 2025Guru - Experienced User
It would help to have a detailed description of "drops". i.e.
- The WiFi signal disappears temporarily, or the WiFi signal does not disappear?
- Both devices connected with Ethernet and devices connected via WiFi are affected?
- When this happens every device connected to the system is affected the same way?
