ocnblue
Oct 16, 2025Tutor
RBE771 Connection Constantly Dropping
I have an RBE771/RBE770 that I have had running for just under a year. My current setup I am using Ting and I get 2GB up/down. They have a fiber modem which I run into the Orbi and I also have a NET...
CrimpOn
Oct 16, 2025Guru - Experienced User
Another question is which type of communication is affected?
Can devices connected to the system communicate with each other?
For example, can they ping another device? Can they ping the router?
(although we generally think of ICMP [ping] being a 'computer function', there are apps for smartphones and tablets which can do ping.)
Does anything appear in the Orbi log when these episodes occur?
