ocnblue
Oct 15, 2025Tutor
RBE771 Connection Constantly Dropping
I have an RBE771/RBE770 that I have had running for just under a year. My current setup I am using Ting and I get 2GB up/down. They have a fiber modem which I run into the Orbi and I also have a NET...
ocnblue
Oct 16, 2025Tutor
Thanks all -
I spoke to Ting - they can see the drops but they are saying it does not appear to be on their side. The connection has been solid. They are sending me an Eero System to see if it is the Netgear setup or on their side. If we continue to see drops, they will come out and look at it.
On the RBR, I am not seeing any lights at all but will check it again when it happens.
The ONT is a Calix 1100X
My Cables are running STP from the ONT to the Router and Router to my switch. I ordered two new Cat6A Patch Cables(S/FTP) that will be here on Saturday. I will replace those for grins.
Traffic Meter, Armor and Parental Controls are not on.
- FURRYe38Oct 16, 2025Guru - Experienced User
How about IPv6?
Also are you using ISP detected DNS or custom DNS? If ISP, please try custom DNS like cloudfare or quad9.
What is the model# of the switch connected behind the RBR?
I presume you have tested the RBR with out the switch being connected?
