ocnblue
Oct 15, 2025Tutor
RBE771 Connection Constantly Dropping
I have an RBE771/RBE770 that I have had running for just under a year. My current setup I am using Ting and I get 2GB up/down. They have a fiber modem which I run into the Orbi and I also have a NET...
ocnblue
Oct 16, 2025Tutor
I enabled IPv6 - did not realize that was disabled.
The switch is - MS308E-100NAS.
I will give you suggestion a tr this weekend.
Oct 16, 2025Guru - Experienced User
Ok, check with ISP to see if they support native IPv6. If they don't then you can keep IPv6 disabled. If they do, ask them which IPv6 configuration is needed.
