kudzu336
Oct 09, 2025Aspirant
RBE771 slow download
I'm having the same issue but everything I've tried is over a wired connection - no wireless. This is what I've experienced. I've just started using Ziply Fiber and signed up for the 2000Mbps...
hendriks05
Oct 28, 2025Guide
I had same issues than you, and turned out to be the IPv6 that is on by default in the 77x system.
Give it a try and disable if on. Good luck!
