lucapelo's avatar
lucapelo
RBE871 slow speed
Hi All,
just installed my brand new RBE871 and I’m getting a constant 94MB download/upload speed. If I connect my laptop to the ethernet port of the wall I get 850MB download.
I have a main router in my house (FritzBox!5590) provided by the ISP, which delivers  connectivity to the entire walls, this device is wifi disabled.
the Orbi is intended to deliver wifi connectivity.
Wires in the walls are CAT6A.
each wired port in the house gives me high speed, just wifi from Orbi is slow at 94MB. I already downloaded the update firmware and restarted the Orbi a few times.
I’m not a tech guy. Thanks for suggestions.
  • CrimpOn's avatar
    CrimpOn
    Could you please use the web interface to display the Advanced Tab and click on Show Statistics:
    What does the router display for the WAN port?
    • lucapelo's avatar
      lucapelo
      It shows 100M/Full. I restarted the 871 and went to 1000M - immediately the download speed went to 960Mb via WiFi (both on my MacBook and my iPhone 13). Was so happy.
      Unfortunately the day after, WAN shows again 100M/Full - and the wifi speed is back limited to 93Mb.
      How to keep the WAN port at 1000M/Full (even after a power cycle of the Orbi)?
      thanks
