TOPS119
Apr 14, 2026Luminary
RBE970 / RBE971 Firmware Version 12.1.8.7
So I have updated the RBE971 successfully but the Rbe970 satellites firmware fails, anybody else having this issue is the server down ?
TOPS119
Ok I have downgraded back to what you sent me thanks.
- FURRYe38Apr 14, 2026Guru - Experienced User
Ok sounds good. You can use that in mean time.
Will make sure NG posts next update correctly when they get ready for the 970 series. Think one hand didn't hand shake with the other correctly.
- mlfxApr 14, 2026Aspirant
How did you the downgrade?
FW files are needed to downgrade.
Does your system need downgrading?
What region are you located?
You have the 970 series system?
Does your system need downgrading? - Yes, i Need it
What region are you located? Italy - Europe
You have the 970 series system? - Yes - the RBE971B
