TOPS119
Apr 14, 2026Luminary
RBE970 / RBE971 Firmware Version 12.1.8.7
So I have updated the RBE971 successfully but the Rbe970 satellites firmware fails, anybody else having this issue is the server down ?
TOPS119
Ok I have downgraded back to what you sent me thanks.
Apr 14, 2026Guru - Experienced User
Ok sounds good. You can use that in mean time.
Will make sure NG posts next update correctly when they get ready for the 970 series. Think one hand didn't hand shake with the other correctly.
