TOPS119
Apr 14, 2026Luminary
RBE970 / RBE971 Firmware Version 12.1.8.7
So I have updated the RBE971 successfully but the Rbe970 satellites firmware fails, anybody else having this issue is the server down ?
mlfx
Apr 14, 2026Aspirant
How did you the downgrade?
Apr 14, 2026Guru - Experienced User
FW files are needed to downgrade.
Does your system need downgrading?
What region are you located?
You have the 970 series system?
mlfx wrote:How did you the downgrade?
- mlfxApr 14, 2026Aspirant
Does your system need downgrading? - Yes, i Need it
What region are you located? Italy - Europe
You have the 970 series system? - Yes - the RBE971B
- FURRYe38Apr 14, 2026Guru - Experienced User
Ok, sent you a PM. Please reivew it there.
Thank you so much, rollback done!
Unfortunately, I had to do some more firmware upgrades to bring it back to the "current" European version, V9.13.2.1_1.3.35.
Furthermore, once I rolled it back, it retained all my previous settings (I use it as an AP) connected to the router, but the devices couldn't obtain an IP address...
I did a hard reset and reconfigured everything.
Everything seems to be running smoothly now.
Thanks so much again! I couldn't have done it without you! ;)
