krgoodwin
Jan 15, 2026Guide
RBE970 Satellite Connections
Why does a WiFi device 10 feet away from the satellite end up connected to the Router RBE971 which is a 100 feet away? I've also seen where devices close to the satellite initially connect to the sat...
Jan 18, 2026Guru - Experienced User
Something to check with the devices Mfr. Up to them to pick and choose where they connect and migrate to and from.
Speed will decrease with distances, noise and interferences.
- krgoodwinFeb 04, 2026Guide
Not an accurate statement. For some of the newer WiFi frequencies and protocols, the speed will decrease as the distance decreases. This is usually considered the near field environment.
- FURRYe38Feb 04, 2026Guru - Experienced User
Yes and also depends on how the device picks and chooses which frequency to connect too. Some detection algorythms may not be good with client side devices. I found this out with NEST controllers back on 2020 with Orbi AX series. Would ping pong around unable to connect to multi signal AP configuration. Worked with NG for months on this and was determined NEST had to make some changes there side to help the controller work with multi singal source systems and stop the ping ponging around.
Placement of the RBR and RBS and how many RBS are deployed and distanced in between are also a factor for Orbi systems.
Orbi systems are multi signal sourced systems while the R9000 is only a signal source signal router.
- StephenBFeb 04, 2026Guru - Experienced User
Do you have a reference? I am aware that if a client is very close to the router that the router transmission can overload the RF front end in the client (signal saturation). But I haven't seen anything else on this.
Generally, saturation is only a possibility if the the client is less than 5 feet from the router/AP. FWIW, I agree that distance is not the only factor. The details of the environment matter (reflections, objects that block the signal, etc).
As far as I know, near-field environment generally describes being within two wavelengths ot the transmitting antenna. Which would be about 4 inches for 6 ghz, increasing to about 10 inches for 2.4 ghz.
