bloosqr
Oct 20, 2026Aspirant
RBE970 satellite does not bridge traffic between its own 5 GHz and 6 GHz clients (V12.1.11.15)
System: RBE971 router + 3x RBE970 satellites, all on firmware V12.1.11.15 (no newer firmware offered). Main SSID on 5 GHz + 6 GHz, WPA2-PSK + WPA3-Personal mixed mode, 5 GHz channel 40. IoT SSID is s...
FrumpyGrandpa
Oct 20, 2026Luminary
If the older iPhone is connected to a different Orbi unit (not Satellite 3), does it respond to ping and (what is the TCP probe?)
i.e. does the problem exist only when devices are connected to the same satellite?
