bloosqr
Oct 20, 2026Aspirant
RBE970 satellite does not bridge traffic between its own 5 GHz and 6 GHz clients (V12.1.11.15)
System: RBE971 router + 3x RBE970 satellites, all on firmware V12.1.11.15 (no newer firmware offered). Main SSID on 5 GHz + 6 GHz, WPA2-PSK + WPA3-Personal mixed mode, 5 GHz channel 40. IoT SSID is s...
Oct 20, 2026Guru - Experienced User
What model is this older iPhone?
What iOS is loaded on it?
Seems maybe this one particular phone could be the factor...
Have a different 5Ghz only device you can test with.
