bloosqr
Oct 20, 2026Aspirant
RBE970 satellite does not bridge traffic between its own 5 GHz and 6 GHz clients (V12.1.11.15)
System: RBE971 router + 3x RBE970 satellites, all on firmware V12.1.11.15 (no newer firmware offered). Main SSID on 5 GHz + 6 GHz, WPA2-PSK + WPA3-Personal mixed mode, 5 GHz channel 40. IoT SSID is s...
bloosqr
yes I can confirm it works perfectly if I connect it to a different satellite (or presumably the router). Just retested this with them back on the main SSID with the 5 ghz iPhone in the basement and my 6ghz laptop on the top floor.
The only place this shows up is if they are both on the same SSID and on the same satellite.
donawalt : I am not 100% sure I have another iPad that only connects via 5 ghz (but I might) let me see if I can replicate the same behavior on that. The older iPhone is an iPhone 12 (the newer iPhone is a 16). That is interesting that is working for you are you on the same / latest firmware? (mine is an m2 pro iPhone 12 and iPhone 16 I am noodling with).
Oct 20, 2026Guru - Experienced User
I have a iPhone 12 Pro Max. Haven't used it in a while. I'll put a charge on it and check this with my iPhone 17 Pro Max both on same RBS.
Testing with a 870 series here.
