bloosqr
Oct 20, 2026Aspirant
RBE970 satellite does not bridge traffic between its own 5 GHz and 6 GHz clients (V12.1.11.15)
System: RBE971 router + 3x RBE970 satellites, all on firmware V12.1.11.15 (no newer firmware offered). Main SSID on 5 GHz + 6 GHz, WPA2-PSK + WPA3-Personal mixed mode, 5 GHz channel 40. IoT SSID is s...
bloosqr
I hunted around to see if I could find another 5 ghz only machine .. my iPad is an m2 so is 6 ghz also. That said I just realized I have a raspberry pi 5 sitting around that I used to use as a pihole/DHCP server. I am reformatting that and going to see if that connects as that will confirm this is not some accident of iOS and truly a 5 ghz / 6 ghz thing.
If that does not connect wireless and connects wired I will retest on another 970 somewhere and also try your channel idea.
I unfortunately do not have wired backhaul but should ;)
Yes have checked the devices and via orbilogin to see match IP addresses / Mac addresses and SSIDs...
I do have that protection engine on.. I do not know what that is actually.
donawalt
Oct 20, 2026Hero - Experienced User
Try a quick power cycle of the 970 - it's fast and easy to try.
