bloosqr
Oct 20, 2026Aspirant
RBE970 satellite does not bridge traffic between its own 5 GHz and 6 GHz clients (V12.1.11.15)
System: RBE971 router + 3x RBE970 satellites, all on firmware V12.1.11.15 (no newer firmware offered). Main SSID on 5 GHz + 6 GHz, WPA2-PSK + WPA3-Personal mixed mode, 5 GHz channel 40. IoT SSID is s...
bloosqr
I can confirm the same symptom on the raspberry pi 5. I do not really want to power cycle the satellite but I will try this now.
