Kenttay's avatar
Kenttay
Follower
Jun 12, 2025
RBE971 - ECCN & HS Code
Hello... I would like to enquire on the ECCN and HS Code for RBE971. Appreciate someone able to advise, thank you.
  • Keep in mind these devices are not intended for worldwide usage, regulatories like the US FCC don't allow user changes of the regulatory area.
    Beyond, the regulatory and compliance markings on the devices (like UL, CE, EAC, UKCA, ... must match the ones required for the operation (== import) region. Customs can confiscate illegal devices on behalf of the regulatory body, and the receiver can and will be fined.
    ECCN      Import HTS    Export Schedule B    CCATS
    5A992    8517.62.0050    8517.62.0050    G172297
    FMI: https://www.netgear.com/about/regulatory/
    This is a community, and we don't have neither formally Export/Import documents nor Certificate of Volatility available here.
1 Reply
  • schumaku's avatar
    schumaku
