SM004346's avatar
SM004346
RBE971 additional Access Points
Hi, I need to extend my WiFi coverage to some far areas, not reachable through the Current mesh setup: one RBE971 + 2 Satellites.
Which are the suggested wired Access Points to use (e..g. WAX 620 or similar)?
Thank you
Sergio
  • You can wire in the EAX80. If its far enough away, your devices own roaming protocol will work fine and you can name them the same. Just set it up in access point mode and make sure the wireless channels used aren't the same to prevent interference.
    • SM004346's avatar
      SM004346
      Agree: RBE970 would indeed be a price overkill.
      But EAX80 is a non wire-able range extender and I'm afraid I can't
      guarantee any range overlap with the rest of the mesh system. I need to go for a good access point more than a range extender.
      Thank you
      Sergio
      • plemans's avatar
