mhef99
Apr 21, 2026Initiate
RBE971 AP Wi-Fi drops, wired stable
Same issues here. So frustrating given to cost of this setup!!!!
Apr 21, 2026Guru - Experienced User
So please give more information regarding this.
What is happening?
What region are you located?
What configuration are you using? Router or AP mode?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Using ISP Detected DNS or custom DNS?
Is IPv6 Enabled or disabled?
Which ISP are you connected with?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls, IPv6, Traffic Meter.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
