KTdr53
Aug 04, 2026Aspirant
RBE971 crashed, will not power back up
Purchased a Orbi WiFi 7 router and two satellites in late November 2024. Generally, the devices and network have worked well. Yesterday, however, the router suddenly went down, and I’ve been unable ...
KTdr53
Aug 05, 2026Aspirant
Thanks for the suggestions. I swapped the power adapter from an RBS, and it did not power the RBR on. On the other hand, the adapter from the RBR did power up the RBS. So unfortunately, it does not appear to be a failed power adapter.
Aug 05, 2026Guru - Experienced User
Good check. Seems that the RBR has failed. Might find a used on Amazon or fleebay maybe...
