EricTheRedFL
Jul 27, 2026Aspirant
RBE971 dropping A9000 connections
Hello, I've got an RBE971 running v12.1.10.12_5.3.16 in AP mode. I have an A9000 adapter for my Fedora Linux notebook that connects correctly. However, after about 5 minutes, the connection is dr...
EricTheRedFL
Jul 28, 2026Aspirant
It's linking on 48 and 69, tx power is 23 and 12dBm respectively.
There are no RBS involved. I just have a small condo.
This is my only wifi7 adapter at the moment. It is 12 ft. directly across the room, clear line-of-site between the adapter and the RBR. I'm using the mainline kernel drivers included with Fedora. This behavior isn't specific to a kernel version, as I started having the problem under Fedora 44 and now have the A9000 conntected to a Fedora Rawhide (bleeding edge version) that behaves the same. The problem started under 7.1.something kernel and continues with 7.2.0-0.rc4 for F45. The Linux driver loads the mt7925u (u for usb) driver within the mt7
cfg80211 1691648 4 mt76,mac80211,mt76_connac_lib,mt7925_common
mac80211 2076672 4 mt792x_lib,mt76,mt76_connac_lib,mt7925_common
mt76 184320 6 mt792x_lib,mt792x_usb,mt76_usb,mt7925u,mt76_connac_lib,mt7925_common
mt76_connac_lib 122880 3 mt792x_lib,mt7925u,mt7925_common
mt76_usb 49152 2 mt792x_usb,mt7925u
mt7925_common 184320 1 mt7925u
mt7925u 16384 0
mt792x_lib 86016 3 mt792x_usb,mt7925u,mt7925_common
mt792x_usb 16384 1 mt7925u
I haven't trashed my Win11 partitions yet, so I'll boot WinDoze and compare config output.
